What a super special, it's good to see someone's dream turn to reality.
Even better when it shows your passion in your workmanship.
Car type: Seven Special
Any idea what it weighs?
Paul N-M
24-08-2017, 08:54 PM
(This post was last modified: 24-08-2017, 08:56 PM by Duncan Grimmond.)
Can we do guess the weight of the cake please? Will there be prizes and forfeits? ;-)
I'll go for 363 kg.
BTW, the later pics are also evidence of a lovely job. Will it be out to play anywhere near me in N.Yorks by any chance?I would really like to give it a careful look over as all the details appeal...
I think there's quite a bit of weight in those extra bits and pieces, so i'll go for 377kg; fruit cake is fine, as long as there's plenty of marzipan and icing!
At country shows I always was under the impression that if you guessed the weight correctly you got to take the cake home...
I suppose I'll have to give that notion up as we haven't been asked for an entry fee!
(If it's got to be Hobnobs I want plain chocolate ones)
A lovely looking little Special, well done !! I'll weigh in for 368kg's...better make sure those chocolate Hobnobs are packed for International travel....
I'm curious about the distributor placement and how you drive it, also the head with the welch plugs on the side, central water off take etc, etc..... On both our single seaters we've modified the dizzy end plate & drive to seat up against the alloy cam gear casting cover, so dispensing with the generator but keeping a short shaft as short of running it from the nose of the cam we couldn't see any other drive options
A lot of 'stuff' under that little bonnet, must have taken many hours of careful engineering, I know how long it's taken us and we've only built ours as a Hillclimb special, no generator, 12v alarm battery to provide the sparks, changed for a fresh one half way through the day. Hand pressurised fuel tank etc. Far simpler than yours
How have you secured your rear panhard rod, I presume from that substantial tube frame behind your back ?
Greig
