05-04-2022, 10:15 AM
Google suggests "Polychlorinated Biphenyls" and suggests this as a resource ..
https://safety.networkrail.co.uk/wp-cont...e-Note.pdf
Runbaken Oil Coils
05-04-2022, 11:40 AM
Crikey, what with a lifetime of handling old engine oil, cellulose paints and thinners, asbestos brake dust flying around and now Runbaken coils, it’s a wonder I’m still here!
05-04-2022, 01:23 PM
(05-04-2022, 09:31 AM)AustinWood Wrote: What is PCB? To me that means Printed Circuit Board. https://en.m.wikipedia.org/wiki/Polychlo...d_biphenyl We dealt with this regularly in railway sidings... I wanted an oil coil for my special until it dawned on me what the oil was. Other than risking birth defects in your progeny and cancer, I can't really see any drawbacks.
(05-04-2022, 01:05 AM)A G Wood Wrote:When I built my current garage in 1979 the cheapest fluorescent light fittings I could find were made in East Germany - from memory about £2 each for a 6-foot unit. I took the last surviving one to the tip just a few months ago. One wonders.....(04-04-2022, 05:24 PM)Martin Baker Wrote: There is a step at the bottom of the thread for the acorn, which would appear to prevent the ignition cable from actually making contact with the coil output. Is this intentional? Is it an air gap? In which case to what purpose? I have always got around this by dropping a small nut in the void.
05-04-2022, 02:22 PM
I was thinking the same as AG Wood, that there was a special Runbaken nut. Love to see a picture, if anybody finds one.
05-04-2022, 02:36 PM
05-04-2022, 06:45 PM
Look down the screw hole and you should see what I mean. A shoulder preventing the lead disc making contact.
05-04-2022, 06:49 PM
Ah, I see.. I will look again...
05-04-2022, 08:52 PM
(04-04-2022, 08:35 PM)John Cornforth Wrote: This might be of interest: I can't imagine that the oil is the insulation, surely it is just for cooling, conducting the heat away from the varnish insulated copper windings. Does anyone know why they used this dangerous oil? Presumably the common oil-filled coils of the fifties through to nineties were using a different oil?
05-04-2022, 09:51 PM
A year or two ago at a public car show one of the 12v Bradfords had been fitted with a 6v coil. The igniton had been left on and whilst several curious were examining the unusual motor the coil exploded...... It definitely had oil in it!
I dont know when PCBs arrived, probably in the 1950s along with many other nasties. Presumably transformers were oil cooled before PCBs. And presumably when used the PCB concentartion was more like 100%. With a normal mixture very little is required to ignite. I have a handbook for a Pratt and Whitney Double Wasp and the plug gap is just .012". Big gaps and fancy voltages are requird for weak mixes as moderns and as erratically occur at idle and starting. From extensive everyday experience with my RP I suspect plug gap influences effective advance. |
