I'd shy away from "flat" as a target and look to re-radius to a much broader radius. Whether it's 3/4 or a little larger is a matter of choice but I'm with Dave here. It's the single best improvement to breathing, whatever the rest of the engine
Charles
07-03-2018, 01:05 PM
(This post was last modified: 11-03-2018, 11:58 AM by Speedex750.)
I've just had a road cam done by Paul Bonewell, in conversation with him he said that 0.8" is the maximum radius that should be used otherwise the follower digs into the flank causing very high wear. I do know of an engine that does have completely flat followers, it doesn't do many miles per year and is still going, but I'm not recommending this.
Expanding the topic slightly, I also found out the hard way that re-profiled cams may need the end of the follower narrowing - tapering in the flat sides either side of the radius. I've seen followers like this before but only with the current engine and cam have I ended up with them riding on the unground part of the shank giving very odd timing and lift figures. The tappets seem to be slightly offset to the cam lobes and if the re-ground area is quite narrow the follower can ride on the shank of the camshaft. Beware!
Dave
I dug out a set of cam followers. One of the 8 is not countersunk for the lock nut. It came in a set of 8 s/h ones from a cherished supplier. Being English, didn't complain... Any reason why it isn't countersunk?
Dave... Can you countersink it? If not I may dig deeper and see if I have another...
07-03-2018, 05:44 PM
(This post was last modified: 07-03-2018, 05:47 PM by Austin in the Shed.
Edit Reason: add content
No I can't countersink it but there are plenty of them about,I can find a spare if you can't.
Another thing,or two to mention is to check they are not split due to over tightening and the bronze guide will likely need shortening, (1/8" or so) even on just reprofiled followers or the locknut could rest on it(ie the follower doesn't touch the cam)
Reduce length on guide on tappet chest end.
Just got my reprofiled follwers back from Dave, nice job, well pleasd.
Thanks Dave
Funilly enough, so did I. First class job. Thanks Dave.
