I believe there is a cunning way of ensuring the master spline is in a known position when offering up the engine - I am sure I have seen it mentioned on here somewhere before? It involves putting the car in gear and then marking the drive flange at the rear of the gearbox to show the pre-set orientation of the master spline. If the spline is then knocked and moves, this is then obvious, and it can be put back to 6 o'clock or where ever you need it to be for a fit.
That's it. Just put the gearbox in top gear and mark the position of the spline on the output flange with a dot of tippex. If you can turn the engine so the blind spline is at TDC and put the tippex dot also at the top, assembly is a piece of gâteau.
does that work ok fitting in the car?
