22-02-2022, 02:46 PM
With an 1 5/16" 2-bearing crank we used to take 20 thou off pistons 2 and 3.
Pistons protruding
22-02-2022, 04:15 PM
Many thanks for your thoughts gents, I probably should have mentioned that it is dry assembled and without any base gasket at the moment. I must say I hadn't expected base gaskets to be as thick as 17 or 27 thou. So I guess when compressed even the thin one would probably bring my pistons down to deck height, which would leave the head gasket thickness as clearance on No.s 1&4 and I could reduce 2&3 by a small amount if I feel it necessary.
22-02-2022, 04:28 PM
Be careful that the head gasket doesn’t overlap the cylinder holes. If you have +80 rebore sometimes it can.
