Am I able to remove the torque tube complete with the back axle on my 32 7 van? I have obviously disconnected the front propshaft and also disconnected the chassis mounting ball so the spherical housing can swing round. The advantage would be that I can then set up the diff etc etc including assembling the torque tube and its nut on the end of the pinion gear shaft without disassembling it to re-install.
I originally assembled it all with no body on so there was plenty of room but now it is a different kettle of fish!
Hi Nick, it shouldn't be a problem. The torque tube mounting will pass over the chassis and under the tunnel. You will either need a trolley jack or three arms!
Unless there is some peculiarty about vans it is customary to remove as a unit, although the torque tube can be removed complete. But care is necessary to note adjustment, where shims fell from etc. Depending on the type, the pinon bearing may be quite a tight fit. There was extensive here recently about removal of the cotters, pursuading the unit back in between the springs etc. Might be worth searching.
Thanks Lance and Bob ... encouraging. Ref the flange at the front end with the nut that claps everything together I can move it back and forth by about 1/8" so something was not 'home' properly. Could be ominous as that means pinion would have moved in and out of mesh. An accompanying 'clonk' on forward/reverse. That is why I am investigating plus one rear hub that has too much runout.
Sounds distinctly ominous. We all await developments with interest. Does the whole torque tube telescope or "just" the universal joint?
I got the axle complete with torque tube out by using two trolley jacks (ie with wheels) with each axle half 'bunge'ed' to the jacks to avoid slipping off. I had already disconnected the front prop shaft and the chassis mounting ball etc and swung that to one side. The whole thing came back easily by pulling both jacks. I found that the large nut that clamps the angular contact bearings to the pinion was not tight and some way away from the bearing face thus giving me that unwanted movement. So Parazine, you were correct. The nut had the old grub screw tightened against the flat on the shaft wire locked to stop it turning. The wire was copper and not my usual locking wire. Of course tightening the nut led to the grub screw being in the wrong place ... reminiscent of getting the split pin in the end of the halfshaft! I think I must have assumed (some years ago) that the nut at the other end of the shaft clamped everything up and left the other nut where it was. If all else fails, read the instructions ! I am trying to find a tab washer to use instead of the grub screw. Just a tip for others who might be removing their back axle...I removed the brake shoes on one side but then realised that was not necessary as the backplate has to be removed from the axle complete with shoes and dangling from the brake cable ....now in bags to keep the shoes clean. Crown wheel and pinion does not look any worse than when I first rebuilt it all a few years ago ..... I think.
If the pinion teeth are long so not all engages, it is prudent to carefully remove the wear step with a Dremel or suchlike before attempting any mesh adjustment. Later pinions were made shorter to avoid (and a lesser step appeared on the cw).
It is curious that this nut is so often loose. It expereinces little radial load to work it on shaft. It is not a crime to grip the shaft very tight in a vice. Someone some time ago published a grand photo of their wife showing how it is done .
