17-01-2022, 06:48 PM
After the emasculation of Nitromors, what do people use nowadays? I have been using Biostrip to some good effect, but wondered whether anyone had any suggestions for a killer product?
Hugh
Hugh
Good paint stripper?
Hugh
17-01-2022, 06:53 PM
Depends what you are stripping Hugh.
If it is alloy I would strongly advise against chemicals and use soda blasting. If it is steel ,chemical stripping is OK I take the item for dipping locally having found modern strippers one can buy to be ineffective.
17-01-2022, 07:00 PM
I'm refurbishing a couple of ST38s, which are pressed steel... I don't have access to anyone who does stripping locally (well, not since I was a young man..)
17-01-2022, 07:15 PM
wouldn't something as small as that just respond to wire wool, a Dremel "chimney brush"-type wheel and/or the electrolytic de-rust method?
17-01-2022, 07:45 PM
Hi Hugh,
"Perfecta" paint stripper from Mylands is pretty much as good as Nitromors used to be. You need to fill in a form to prove that you will not drink it or do anything else daft with it. It works well.
17-01-2022, 08:10 PM
thanks Lance. I dont think wire wool will touch the original paint and, sadly, I dont have a dremel, so a paint on solution is really what I seek..
17-01-2022, 08:14 PM
I've been using this stuff since Nitromors stopped being a paint stripper and became a paint pacifier https://www.carcolourservices.co.uk/prod...-stripper/ it's very effective, but wear decent PPE, it burns your skin just like the old fashioned stuff.
17-01-2022, 08:21 PM
the varnish stripper in the mauve can they sell ar Wilkos is pretty much as per the old nitromorse
17-01-2022, 09:08 PM
Have a look at the hazard label, if the stripper is to be effective, it will contain Methylene Chloride (Dichloromethane for the under 60's). According to a law passed in 2010, this substance is restricted to products "for professional use only" and it's removal from Nitromors and other consumer products left them without teeth.
There are a number of eBay sellers who make these professional products available to you and me. Make sure that you use any stripper with Methylene Chloride in a well ventilated place. It can be lethal......
17-01-2022, 11:08 PM
That's the sort of accolade I want to see on any product of quality
'Can be lethal' :o) |
