Car type: Austin 7 Mulliner
I cannot get my ignition circuit to work since taking my sm5 panel apart to clean all the contacts.
Now the ign light does not come on when I switch the ign switch and there is no deflection of the ammeter.
I suspect that the contacts on the back of the switch are too well worn.
Has anyone had similar problems and managed to solve them.
BTW the lighting switch works normally
Robin
Please All do not use WD40 on your electric contacts...WD =water dispersant. It leaves (or used to a few years ago so still does unless formula changed) a coating on the surface when dried out.....how do I know? story.....
At sea, large ship with whole ship many speakers and control boxes for announcements. Each speaker box and control box had several multi-contact large relays (the type large enough that you could use a contact burnisher on to clean the contacts). I tasked a junior officer to go round and service the, fully waterproof, boxes.....he did so by spraying all relays with WD40.......chaos resulted with many controls/speakers not working. He had to spend a long, long time cleaning every individual relay contact until all was again working.
There is a purpose formulated electrical contact cleaning fluid available. For switch contacts there is also a CONTACT GREASE specially for the purpose that you smear a very thin cote on the contacts. It prevents sparking and hence burning of the contacts.
Dennis
11-09-2021, 03:42 PM
(This post was last modified: 11-09-2021, 03:52 PM by robinhayes25.)
Thanks Mike, ironically this is where it started. Having read the SM5 reconditioning post from the Cornwall club.
I thought I would give it a go. The painting and lettering took me some time to get right but I think I may have disturbed something on the back of the panel when I cleaned it up.
Everything works lights etc and an ammeter deflection when switching
on the lights.
But no ignition light or ammeter deflection when switching on the ignition. The contacts on the back of the switch and the copper/brass tails look worn too.
Thank you too Dennis, I considered using WD40 but resisted it. Do you have a name for the cleaning fluid you mentioned inhibisol perhaps ?
Also, does anyone refurb the SM5 panel ?
Thanks Stuart this has been very helpful
Some versions of the sm5 have very fine wire wound around the lamp holder for the ignition light. Could this have been disturbed causing the lamp to fail?
Peter
Cleaning fluid....Electrical contact .....I used a Screwfix spray can but see they do not seem to have it listed anymore code 17861.
Contact treatment Grease.... RS 566-730. I have had this tube for many years as it is used so sparingly as a smear only.....a small paintbrush is useful.
RS do a list of contact cleaners. Each has a set of data sheets that tells you all about them so you can choose what is most suitable.
As RS is a specialist electronics firm I tend to think they know the products.
Anybody else had good results from their contact cleaner product?
Dennis
