  • 1 Vote(s) - 1 Average
Reliant Regal Pistons?
R4 is 1.5" crank, no?
Well sort of - it’s metric.
(04-08-2021, 09:43 AM)Chris KC Wrote: My set had an oil control ring missing, I replaced it with one of Jamie's - as far as I can tell they are identical.
I may have a set of Regal pistons with A7 rings on I suppose - but the clearances seem about right.
My Googling suggests some modern makers now use bronze bushings in aluminium pistons (e.g. VW).
I also found a supplier of bronze 'repair' bushings for worn Scott Motorcycle pistons.
No takers?
Austin 7 ring = 5/32", Hepolite 17229 ring = 1/8". QED?
Parazine - I don't have the parts to hand and may have confused myself.
Either way, if you have a piston with rings this would not be a barrier to using it.
The pin size is not insurmountable, but in the present spares environment it seems not quite justified spending time or money on the job.
I concur. That's why I nicked the compression rings and relegated the 17229 set to the autojumble pile for someone else to use or worry about!
I think I might hold on to mine - could be made to work if the need arose. We are blessed with good supplies of important parts at present but that can change so easily.
