The information on the web suggests that Fernox F1 should be right for iron and aluminium. Possibly your water in that area is soft with a relatively low pH. I suggest that distilled water is best. Water from a dehuidifier is effectively just that, or you can use water from defrosting the fridge or freezer. If the deposit is soft as you say, power flushing with a hose alternately in each engine connection on an annual basis will probably clear the system usefully. I have to admit that I do not worry unduly about my cooling systems unles there are signs of a problem.
Location: Me: Dore, Sheffield Car: Rowland, Peak District
Car type: 1933 Box Saloon
Is there any reason why you wouldn't just use normal modern car coolant? Its designed to work with both Alu/Iron and has the relevant corrosion inhibitors. It is probably also better suited to the higher running temperatures of an engine vs a domestic heating system (90-100C vs 60-70C)
Car type: RN box saloon
What is against soluble oil ? Most corrosion inhibitors raise the boiling point but beccome corrosive after a certain time. And in some parts of the UK an anti freeze is needed.
07-08-2021, 03:42 AM
(This post was last modified: 07-08-2021, 07:05 AM by Bob Culver.)
There is an Australasian standard Type B which has no anti freeze property and is relatively cheap. I have used for decades in ny Hillman and the iron is as new. Slight corrosion of alloy occurs. Gather it has Specific Heat near 1, much better than anti freeze., and rumoured used in competition cars.
I guess that's what the Penrite product is Bob. A little dearer than CH additive but (one presumes) formulated for automotive use.
I was using it in my Ulster rep but it seemed to be reacting with the enamel paint on my rad surround and bonnet front, so I have 'paused' it.
