Hi I would appreciate any leads to source a pair of aluminium backplates to better complete the brake conversion of my Austin 7 .i have rang many suppliers and specialist to no avail . I wonder if any members have returned their brakes back to original and may have a pair of aluminium backplates that I could purchase .
There are a number of owners who are now converting their cars back to cable brakes, so if you are patient you should find a set, and if you are lucky you may even find the parts to keep them working for a few years. Be aware though they will not give you any better braking, simply a different method of actuation.
I'd argue that twin leading shoes is a material improvement. Whether it's worth the weight and complexity is a valid question. And the 3.50x19 rubber is still a limitation.
Agree cable brakes would be preferable , the Race car project I have taken over had already moved a way down the hydraulic conversion route so will try to continue .
06-02-2018, 01:56 PM
(This post was last modified: 06-02-2018, 02:15 PM by Viteran.)
Hi
My 37 Ruby has a hydraulic brake conversion with Morris minor parts, although the back plates have been welded as part of the60’s conversion.
John Barlow ( Nottingham) had them listed (POA) in August2016
Hi
I fitted hydraulic brakes to my 1934 Ruby, where I live, Brighton, to get anywhere, there is always heavy traffic to negotiate, so it is essential to have confidence that the car will actually stop, particularly with modern car drivers!
Hydraulic brakes do give slightly better braking due to the slightly increased surface area of contact with the drums, but as Ian says, it is the actuation that is different and hydraulic brakes are significantly more efficient with most of the pedal effort being transmitted to the point of use.
Furthermore, the hydraulic set-up normally features twin-leading shoes, rather than the original of one leading and one trailing shoe, so the hydraulic braking is more effective taking full advantage of the self-servo effect of the drum rotation (but brakes less effective in reverse).
On my Uncle's Ruby, he has cable brakes so I can compare the two systems, mine are definitely better, BUT, it is a lot of work to install and install right, I have tried to get the installation "factory" looking and it looks right.
On my Swallow saloon, I have decided to retain the cable operation and I am keen to fit the Oxfordshire 7's brake conversion to the fronts to provide twin-leading shoe set-up, which whilst I understand is not quite as efficient at hydraulics is an improvement over the existing arrangement - has anyone first hand experience of their set-up?
Back to the thread, Tony Betts supplied the parts for my car and he was advertising the back-plates awhile ago, may be worth checking in with him?
