if I understand your thread you are saying that the steering arm has snapped. If so then this is a recognised weak point and David C at Austin Seven components supplies new re-engineered arms with strengthened 'corner'.
Andy
It's not for an Austin Seven it's for an Austin 8. No idea if it's the same part. A photo might help.
Ah yes missed that, thanks Reckers, sorry Ally, ignore my post.
It seems the track rod which is affected, not the more serious main arm as on Sevens.I have heard of other makes where track rod failure only became really obvious when the car slowed down.
The reliabilty of moderns always surprises, despite wide tyres, slender components and abuse of the power steering. Older cars weere designed by intuition, negotiated a myriad more turns and noone knows what treatment has been inflicted in the past. Serious crash damage was not remedied by extensive replacement.
Car type: 1929 A7 Spanish Van
Hi Andy ,thanks for your reply and info,appreciated .I will contact David to find out what info he has and if he can help .Cheers Ally
It's unlikely anything from an A30/35 will be suitable, as they have independent front suspension.
28-04-2021, 02:45 PM
(This post was last modified: 28-04-2021, 02:46 PM by Reckless Rat.)
There's nothing on an Austin Seven (Big or otherwise) like that. You're going to need to source it outwith our cherished suppliers if I'm not mistaken. Looking at the ball joint end, it looks like it has been cracked for a while. I would check the other side while you're at it.
