29-03-2021, 11:26 AM
Hi All
I’ve just rebuilt a spare 3 speed box with Andes gears from Andy Bird. I’ve replaced the old box and so far everything seems fine and I think the ratios are an improvement.
However the speedometer now under reads and the odometer records lower miles than actually travelled. I’ve taken out the speedometer drive spindle and found the gear to have 9 teeth. On the original box the gear has 8 teeth. I’ve put the spindle with the 8 tooth gear back in (replacing the 9 tooth gear) and turning the axle by hand turns the speedo drive gear smoothly.
My question is from what gearbox is the 9 tooth speedo drive, AND is it ok to simply change the drive spindle or should I change the gear on on the main drive shaft as well? I hope it is the former otherwise the back cover has to come off
Final question, is anyone making new speedo drive gears as both gears I have seem a bit worn?
