05-03-2021, 03:44 PM
Good post Dave, Bilt Hamber Deox C is good stuff and does no damage.
oxalic effect on good bores and tappet guides?
05-03-2021, 04:38 PM
How do you buy oxalic acid ?
05-03-2021, 05:45 PM
(05-03-2021, 04:38 PM)Austin in the Shed Wrote: How do you buy oxalic acid ? As if you had to ask https://www.ebay.co.uk/b/Oxalic-Acid-Lab...2affd68995
05-03-2021, 06:21 PM
Ah,thanks,Amazon took me to citric acid.
05-03-2021, 06:28 PM
(05-03-2021, 04:38 PM)Austin in the Shed Wrote: How do you buy oxalic acid ? Oxalic acid is also used as wood bleach. I've been buying mine from these people: https://www.agwoodcare.co.uk/products/ox...on_id=6217
05-03-2021, 10:20 PM
High tensile stressed parts should not be subject to acid ie springs, spokes, steering and susp parts.
08-03-2021, 08:38 AM
Jon you only need make simple blanking plates from stiff aluminium sheet to close up the holes, seal with silicone goo.
Warm citric acid does a pretty fair job and is rather less toxic than oxalic.
10-03-2021, 02:21 PM
I've just cleaned two blocks and one head by totally immersing in a rectangular mop bucket for a couple of days and I'm confident that the Citric Acid only dissolves the rust.
The clean up has been excellent and in one case I did a block twice. Problem is that the acid is neutralised after dissolving a certain amount of rust Jim Runciman |
