Be aware that there were/are dud new fabric couplings out there. Talk to your supplier.
New adapter flange from club spares should not have required adjustment of your components, again talk to your supplier. If it's wrong manufacture they need to know, if your components are not from the year models you described , you need to know.
Its an A series in a Nippy I suspect. I remember one at Longbridge in 1982 it had padlocks on the bonnet !!
You are correct dickie, will be quite a short propshaft knowing how long the tailhousing is on an A series Gbox.
18-02-2021, 05:45 PM
(This post was last modified: 18-02-2021, 05:49 PM by Dennis Nicholas.)
Not an A exactly. Not an A box.....begins with a T.
The A box to 7 prop was for when it had the A engine and box......wasn't too short a prop. Next stage needs bit shorter prop.....yet to measure.
Totally irrelevant to thje subject, but can anyone please help with Dave Mann'x latest email adress? The one in the latest Assoc. Grey Mag has just been knocked back. Appreciate help. Cheers, Bill in Oz
The one in the A7CA 2021A magazine is the correct one.
