15-02-2021, 05:45 PM
Mystery Voltage Regulator
15-02-2021, 05:55 PM
Hi Henry,
Yes I have a brand new one in the garden shed. ( I should have the instuctions with it ) Its a Schottky diode regulator made and marketed by Nick Plevin in the 80s / 90s
15-02-2021, 06:02 PM
Is there any chance you could post the instructions?
15-02-2021, 06:06 PM
Hi Henry,
I will have a rumage and see if I remember where its hidden ??!!
15-02-2021, 06:23 PM
Thanks.
15-02-2021, 06:45 PM
I had one on my special for 25 years with no problems, don't expect to much output or it will fail.
When I had the Dynamo rebuilt 5 years ago I was advised to have a new cutout with it as the Plevan one is quite old tech. Andy
15-02-2021, 07:02 PM
had one on my first ulster rep.
i was warned they can fail very easily, the early ones used to fail if the battery went flat?? i wired a connection on mine a bit to tightly, as usual trying to make a tidy job of it. one wire pulled loose, and it failed. put another one on. and it lasted forever. tony.
Here you go - Didn't know that you could attach PDFs
NP1 Regulator Coil.pdf (Size: 282.16 KB / Downloads: 89)
15-02-2021, 08:28 PM
Thank you Charles,
I have found my unit and two sets of instructions which are slightly damp !! You have saved me a lot of swearing at computers in trying to post the instructions !!
15-02-2021, 09:29 PM
Thank you very much Charles and dickie65.
