Can any one tell me how to get my 29 chummy ready for the summer season and/or regular maintenance.( grease, oil, cleaning, etc.)
29 Chummy regular maintenance.
28-01-2021, 01:27 AM
A good starting point is the A7CA onlinr archive :
Austin Seven Online Archive - Austin 7 Clubs' Association | (a7ca.org) And look up the 1929 Austin 7 Handbook: archive.a7ca.org/wp-content/uploads/HB_A7_619D.pdf What is the header for your post ? - possibly better as: 29 Chummy regular maintenance. or similar
28-01-2021, 01:48 AM
Thanks for the suggestions I will get right on that.
28-01-2021, 02:51 AM
Good move
![]() Was the Handbook any help ?
29-01-2021, 06:44 AM
I have not burrowed through the refs but generally reckoned prudent to only part fill diff. And the old idea of pumping hubs full of grease is nonsense. Can stir up what is there with a dowell thru the grese niipple hole. Dynamo output should not exceed about 8 amps charge lights off.
29-01-2021, 08:40 AM
[attachment=12869
Get ready for summer. OK, must check oil levels, plugs, points, battery.....oh, first of all find the engine.
The best way to get "ready for the summer" is to not stop using it in the winter.
A drive on a crisp winters day is to be treasured and whilst circumstances limit usage at the moment, and in Steve's case the absence of an engine, I firmly believe that the best maintenance is usage. Just avoid salty roads.
29-01-2021, 11:52 AM
Seconded.
29-01-2021, 02:10 PM
Yes, Charles has it spot-on!
29-01-2021, 10:33 PM
Be sure to avoid "Maintenance Induced Failure".
