25-01-2021, 04:39 PM
A sensible change though.
Improving on a design deficiency
25-01-2021, 07:22 PM
Slight thread drift but useful to have here perhaps. I'm going to use this later coil starting nut. Is there good advice for changing them over i.e. heat/no heat and where is best place to lock off the crank with engine out. Anything needed like locktight, or just clean and oil before screw in? thanks...
25-01-2021, 09:06 PM
I've not managed to strip one and not heard of one being stripped.
26-01-2021, 01:55 AM
(This post was last modified: 26-01-2021, 02:32 PM by Steve Bryant.)
I have faith in the silver soldered joint. In my experience the base metals fail before the solder joint does and since the spigot of the extension protrudes into the original nuts internal hole by about 7/16" the soldered joint is around the spigot and on faces of the mating parts.
To be honest I didn't feel like machining a new one from a lump of hexagonal rod. Stephen
26-01-2021, 11:15 AM
26-01-2021, 02:51 PM
Thank you all for your comments and observations. I've installed the nut and have been able to get a good torque on it. Time will tell if this idea was a good one or not.
Stephen
26-01-2021, 03:53 PM
It won’t because it probably won’t fail. But, nor have any of thousands of engines using the correct parts.
26-01-2021, 08:40 PM
(25-01-2021, 07:22 PM)JonE Wrote: Slight thread drift but useful to have here perhaps. I'm going to use this later coil starting nut. Is there good advice for changing them over i.e. heat/no heat and where is best place to lock off the crank with engine out. Anything needed like locktight, or just clean and oil before screw in? thanks...Hi Jon I swapped to the later starter nut on the special (1929). I can’t remember doing anything unusual. I think I held the crank with a length of dowel wedged into the case. I didn’t use Loctite although I guess I could have. Cheers Howard |
