Like Bruce’s car, my RP also suffers from badly fitting doors. The drivers side is not to bad, although the side mouldings don’t line up very well. The passengers door tends to stick a bit on the little rubber stops but any adjustments I have tried seem only to make matters worse, so I have left things alone and put it down to ‘patina’.
If you want admins to take action, please report spam postings using the report button - copying the post, as above, simply multiplies the dodgy link.
Looks as though already deleted - thanks.
