Since my car arrived in the US over Christmas, the fuel tap(fuel is drained) has become very stiff. I''ve ordered a spare. However, is there a way to fix a stiff tap? Likely the seals have dried out. Will fuel correct this or perhaps silicone grease? I don't want to find out that a solution didn't work, as the tap is in the foot well above the starter.
Erich in Seattle
I have a very old tube of Hermatite Gold - this works very well for this problem.
The only issue today is locating Hermatite Gold...
Ruairidh, I think I may have some Golden Hermatite somewhere deeply buried. However, I'm looking for something that will lubricate the inner seal(so I don't bend or break the lever) rather than a product to seal the tap. I thought silicone grease as it isn't known to affect rubber, as far as I know.
Erich in Seattle
16-01-2018, 08:29 AM
(This post was last modified: 16-01-2018, 08:39 AM by Ruairidh Dunford.)
I dismantle the tap and put Gold Hermatite on the tap, then reassemble. Tap operates smoothly with no leaks.
If you have a source for Gold Hermatite please let me know.
