06-12-2020, 07:18 PM
(This post was last modified: 06-12-2020, 07:19 PM by Colin Wilks.)
Tony, do you have a date for when these will be available?
I've promised myself to get the RP back on the road by Christmas!
The followeres wear much faster or did on the oils of the time than do chilled iron followers of later makes. But do they ever develop pits in normal use? Either been severely fatigue pitted, very rusty or some original defect. The finish appears woefully coarse and far worse than can be obtained with a fine oilstone or carbide paper finish. Fine finish is usually reckoned vital for cams (at least under any phosphate coating.)
Mine were reground to a larger radius by a friend who rehardened them afterwards using Casenite. I fitted them with a Jack French camshaft. After about 25,000 miles I dismantled the engine to find out why it was noisy. I found a loose little end because the bolt had lost its head but there was no visible wear on the cam followers.
Car type: Seven Special
Well hats off to you Tony.
Paul N-M
Hi Tony
Put me down for 8.
Please do not use these Colin.
You would spoil the job.
Call needed.
07-12-2020, 10:01 AM
(This post was last modified: 07-12-2020, 10:04 AM by Zetomagneto.)
Tony, if your doing them they are going to be affordable .
Top marks again! We are fortunate to be able to get so many parts off the shelf it makes
our hobby so much easier.
Oh yes, a set for me please, 3/4” Rad.
Best Wishes
Gene
hi gene.
ill be well below others doing the split nut.
ill be well below others machining down high tensile bolts.
can we have a guessing game, and see what people feel a new set of 8 followers will cost.
i have a price im going to stick with, but id be interested to see were people feel prices should be.
all are welcome to join in.
thanks tony
