Malcom, Please don’t give us that Sh*t It is far better to use a man made poo. Oops I really meant a scientifically made sealant that sticks like poo.
John Mason
P.s. please excuse the toilet humour.
I cured my sump gasket leak by helicoiling all the damaged sump bolt threads and fitting the sump back with a paper gasket, well covered in grease and new bolts. Still haven't been able to cure the leak from the nearside rear of the block to crankcase joint, though I am beginning to suspect that it is coming from the tappet cover. However, since the engine is using (leaking?) less that 500 miles per pint, I shall live with it.
26-11-2020, 10:27 AM
(This post was last modified: 26-11-2020, 10:28 AM by Reckless Rat.)
David, since rebuilding the engine, mine is pretty near oil tight, but with a similar leak to the one you mention. I have used a silicone valve chest cover gasket but after a run there is always a bit of oil on the bottom right hand corner of the cover. I suspect it is oil mist coming out of the vent holes being blown rearwards by the 4 blade fan, or possibly a poor seal on one of the hold down screws. I have decided that it is less hassle to just give it a wipe down after a run rather than take it apart to try and cure it.
The only problem with having a completely oil tight engine is that it is not immediately obvious that there is any oil inside it!
I quite like leaving the odd drop of oil when I park. It's the Austin 7 equivalent of a dog cocking it's leg.
Just an afterthought - I rarely throw away a sound used bolt or nut - they all go in a plastic rummage-tub. I'd think twice before re-using one on a big end, but for a sump bolt/ stud? Quick clean-up with a thread die and Bob's your uncle. It's hardly a critical application.
