24-11-2020, 04:18 PM
Not sure how he got two carburettors on a single manifold.
His wife is going to be very angry
24-11-2020, 04:56 PM
Shouldn't be an air vent in front of the door.
24-11-2020, 05:22 PM
Having read Ivor’s Input can I slightly alter things and say that the door handles are facing the wrong way I.e. the grip part should face forward.
John Mason.
24-11-2020, 08:23 PM
(This post was last modified: 24-11-2020, 08:31 PM by Tony Griffiths.)
The door has been changed to front-hinged and an extra carb added - but the air vent and tie are in the original picture. There are four other changes; three you might spot - but the fourth is rather dark.
24-11-2020, 08:35 PM
Mr "Shirt and Tie" looks to be no spring chicken. I confidently predict a bad back tomorrow after leaning forward with a lump of cast iron at arm's length !
24-11-2020, 09:15 PM
I guess you've added the foglamp, as it looks identical to the headlamps.
24-11-2020, 11:17 PM
He hasn't got his jacket on!
24-11-2020, 11:53 PM
26-11-2020, 10:13 AM
I thought the starting handle went through a hole in the bottom of the radiator grille not the car body.
John Mason
26-11-2020, 01:41 PM
(This post was last modified: 26-11-2020, 01:47 PM by Tony Griffiths.)
(26-11-2020, 10:13 AM)John Mason Wrote: I thought the starting handle went through a hole in the bottom of the radiator grille not the car body.Good try but, no, that's in the original picture - and altering it convincingly would be quite a job! Changes include: two bonnet catches instead of one; an extra cut-out on the bulkhead; a mirror on the near-side of the windscreen, extra bolts along the front bumper and a second pair of pliars in the toolbox..... |
