Sunday fun with ConfusionStarterMotorMarketing.com Brand new bacon-slicer starter
Am I missing something? Is this really what the seller claims it to be? It doesn't look like one, smell like one or even taste like one - but perhaps it is?
It's offered here: https://www.powerlite-units.com/starters/rac482.html
....by this company: https://www.powerlite-units.com
.jpg   Modern=-bacon-slicer.jpg (Size: 236.33 KB / Downloads: 442)
I know a couple of people who've fitted these, Tony, and they work well. They don't look right, obviously, and I think they're an expensive solution to a problem that doesn't exist if you renovate your original starter motor correctly but, each to his own. Never seen one fitted to a Bacon Slicer, only to the later in cab type and you do have to remember that the torque of these starters when they're activated puts a significant load on the mountings for the alloy starter motor housing, the housing itself and the crankcase.
What puzzled me was that, while the 'arrangement' looks to be in line with the original design, the mounting appears to be a 'flange' rather than a 'foot'. Perhaps there's an alternative model - or might it be supplied with some sort of adapter bracket?
The mounting appears to be a 'flange' rather than a 'foot' fitting. Perhaps there's an alternative model - or might it be supplied with some sort of adapter bracket?
No, Tony. They just bolt straight to the alloy housing flange to flange as the original (later in cab housing, not Bacon Slicer). They make a range of these starters to fit all sorts of pre-war cars the only real difference between them being the angle of the flange fitting and the hole number/spacing dependant on what they're being fitted to. Walk around a VSCC Race/Speed event paddock and you'll see loads of them (although only 2 regular A7 Class 1 cars that I can recall).
Thanks, Steve, for the explanation; all is clear now - though it is an ugly-looking brute of a thing!
(22-11-2020, 01:10 PM)Tony Griffiths Wrote: .......... - though it is an ugly-looking brute of a thing!
My feelings exactly. Wait 'till you see one in the flesh. They work but look terrible Sad I always think they appear capable of ripping themselves off the engine Exclamation
6-volt or 12-volt?
12 volt only.
Well - I've run one for a couple of years on my trials Chummy - That involves a lot of starts I can tell you! I got fed up repairing Austin starters and have had no problems since. The torque starters also use far less power, which has to be a good thing when your dynamo only puts out 6 amps anyway.
Not for an original Concours car, but damn good in the ruff and tuff.............
I didn't say they didn't work, Bob Wink
