Car type: Austin 7 RN 1931
I have a 1931 RN saloon and the various lubrication charts show a removable plate on the rear transmission tunnel to access a lub point on the rear uj/carden.
My car does not have this opening, am I missing a lub point or was it not fitted to my model,
I've laid under the car and felt all around the prop shaft joint but cant find anything.
Sounds like your prop shaft tunnel has been replaced during a previous restoration/repair? All cars should have a removeable plate on the tunnel between the seats to access 2 lube points:
1) On the top of the torque tube hanger bracket, lubricates the spherical bearing, bottom ball joint and the front bearing in the axle
2) On the carden (pot) joint housing. Should be filled with CV joint grease or Moly grease.
Both of these points are sometimes covered with blanking plugs in my experience, so may not be immediately obvious. Number 1 above will be very hard to see without the access opening and impossible to lubricate!
Do you have a body number stamped on the tunnel which would be just behind the gearbox (Under your wooden Box) If you don't, then the tunnel is a replacement.
02-10-2020, 12:58 PM
(This post was last modified: 02-10-2020, 01:00 PM by Barry Townsend.)
Thanks for the info, I'll have to get underneath with a light and a mirror and have another poke about.
It would probably explain the slight knock on the overrun, probably dry as a bone!
Can't find anything so it looks like it's been replaced at some time
