04-01-2018, 12:19 PM
Good title for the next album Ruairidh!
Supercharged Austin seven engine advice
04-01-2018, 12:49 PM
But what will we call the band Chris?
Another downside of publishing pricing is that it may not be accurate/current. Those anticipating Paul Bonewell to grind a camshaft today, at the prices quoted, will be somewhat disappointed (and I have Paul’s permission to say that). (04-01-2018, 12:49 PM)Ruairidh Dunford Wrote: But what will we call the band Chris? Of course none of them are precise - I wrote mine from memory, and that's completely shot through cooking in aluminum pans! If anyone thinks that they can cost the build of a blown Austin engine on a spreadsheet and be close to even the nearest grand they should perhaps go and buy a Caterham instead. Charles
04-01-2018, 02:02 PM
(31-12-2017, 06:05 PM)Zetomagneto Wrote: To give you an idea of cost there was a supercharged engine on eBay at £18000 if you do the maths that's a reasonable price. Charles, the whole pricing discussion came on the back of Zeto’s statement - which suggested that he had done the maths. I was genuinely interested in seeing the workings behind it as this kind of engine, and the costings involved, are way out of my field of experience. I hope that you would agree that it would be unfair to allow an incorrect costing, applied to a specific supplier, to go unchecked both for the supplier and the upcoming customers. If you feel aggrieved - I apologise. On a separate issue can Zeto tell us more about his cranks and rods please? Are these in production or have you made your own? If in production - what form do you offer and how do we contact you?
04-01-2018, 02:10 PM
04-01-2018, 02:14 PM
That is good to know - thank you.
Zeto - your crank and rods, please...
04-01-2018, 02:44 PM
04-01-2018, 03:24 PM
(02-01-2018, 10:30 AM)Zetomagneto Wrote: Here are the specs of my cranks and rods Yes - some latter parts did, of course. I take it the preceding text is TOC as well?
06-01-2018, 09:04 PM
Maybe of interest I have a profile pattern logged in my name with Kent Cams of an original supercharged Ulster camshaft 9c140. The quality of workmanship is some of the best I have seen with the technology to back it up.
Below are the original and reground ones side by side. As you can see if you select the correct age of camshaft to be reground then it barely touches the original base circle. These will retail at £150 plus p&p using a camshaft supplied by the customer
06-01-2018, 09:12 PM
Lovely work!
