15-09-2020, 09:18 PM
(This post was last modified: 15-09-2020, 09:20 PM by David Cochrane.)
I am getting a batch of these mag engine starter dogs made at the moment, partly because I need one for my own car! They should be ready later this year, but I don't know a price yet. I'm also getting the usual coil engine ones made (BB52) and a few of the early coil ones (BB41).
David
Super helpful. Many thanks. I'll report back in due course.
Nick, the size is 7/8W and it is worth investing in a 6 point socket. Unfortunately, as others have said, removal of the little (oil seal) ally housing doesn’t help as the hole in the front case is not big enough to allow the socket to fit. It is worth checking the alignment of the starting handle bracket mounted on the front crossmember. If it is out of kilter or the shaft is a sloppy fit, the shaft will tend to resist engagement. Hope this helps.
AUSTIN REPRO HAVE EARLY STARTER DOGS
TEL 01202 625242
Nick
If you are removing the outer timing gear cover it helps to warm it up carefully so that it is quite warm to touch. I use a gas blowlamp.
Just for once I thought I would try the simple thing first - so I took the advice to see if the starting handle guide was letting the dog mesh properly. It wasn't - by a long way...
Four large washers later the guide is doing its stuff and the handle engages solidly with the dog, to the degree that I can feel confident using it to start the car.
I am very grateful to all for the advice. Thanks.
