12-09-2020, 08:36 PM
(This post was last modified: 12-09-2020, 09:28 PM by Ian Williams.)
I have just checked two F1372 for you, both are NOT 2BA and have a profile the same as your G&L replacement. I wonder if the steel 2BA is home made and has been forced into the carb damaging the thread??
I should have added that my experience of Zenith carbs has been that they all have metric threads
Car type: 1932 AH Tourer
12-09-2020, 10:02 PM
(This post was last modified: 12-09-2020, 10:04 PM by John3528.)
Thank you so much Ian for taking all that trouble. Although it is difficult to see in the photograph, the G&L replacement is a slightly larger diameter than 2BA and so will not even start in the hole. This said, the TPI of both screws look to be about the same and the 2BA is indeed a rather loose fit in the hole so, maybe the threads in the hole have become corroded thus 'shrinking' it.
Having written off the G&L needle, thanks to your researches Ian I shall now look at it again because it sounds as though it should fit. I shall also research different threads to see if there is anything very close to 2BA for which I can buy a tap.
Regards and thank you again.
P.S. Interesting point too about Zenith using metric threads.
I think you will find its an M5 thread John, personally I would clean the thread out with a tap and use the G&L needle
Ian, you are a genius!
The pitch of a 2BA thread is 0.81mm and of a 5mm thread is 0.80mm, which explains why the 2BA screw fitted albeit a little loosely. I only have a 5mm taper tap but it has cleaned up the first few threads such that the G&L needle now readily enters part way. No obvious metal swarf emerged, just some grey powder suggesting that it is just severe corrosion on the threads. A plug tap should clean the rest of the thread and I should be in business.
Thank you again for taking the trouble to look out your carburettors and for your very helpful advice.
John.
I am pleased that you have a good result John, its always nice to hear when a suggestion has helped.
