Charlie my suggestion of welding was not a serious one. Not only would it be a lot of work I think it would be more expensive than the cost of a new one.
John Mason.
I buy SAE30 made and supplied for motor mowers! Delivered at about half the price of "classic" SAE 30....
Awaiting 1st photo of A7 with gang mower attached?
Does it have Zinc added
Mark
What are the other three like?
Maybe a good time to check.
(10-09-2020, 10:40 AM)Bruce Nicholls Wrote: Awaiting 1st photo of A7 with gang mower attached?
This sold a few years ago, (and was discussed on here.)
[Image: 7736142236_a739dc4ced.jpg]
Austin Seven Lawnmower
by Clive Barker, on Flickr
"Does it have Zinc added "
Not at all sure that zinc is needed in an unmodified Seven engine. Modern oils don't have zinc as it damages catalysts.
My son's Maserati engine has cams 25mm dia with a 10mm lift. It revs to 6,500rpm so the rubbing speed of cam on flat follow is huge. Zinc is essential and unworn 2nd hand cams are very rare.
The Austin with small cam, lower lift, curved followers and max 4,500rpm is in a different league.
Following on from Charlie Carpenter’s post regarding a fractured piston, my own car recently developed a noise on acceleration that, at first, I thought was a blown manifold gasket. However, investigation ruled this out, and, to cut a long story short, I decided that it had to be a little end noise. Indeed, so it proved to be. When I dismantled the engine (leaving the crankcase in the frame as I am no longer strong enough to tug the engine out on my own) there was slight but discernible play in number 4 little end. Further dismantling revealed that the “phantom badger” had been at it again, the securing bolt having been fitted without aligning the budget pin correctly, damaging both the bolt and thread in the rod.
I ordered a set of suitable pistons and, having been able to rescue the thread in the rod, I borrowed a bore honing tool from a friend and fitted the pistons together with new small end bolts. Imagine my dismay, having had the engine to bits and carefully reassembled it, when I first started it up, it sounded like a bag of spanners. However, having let it run on idle for about half an hour, without anything untoward happening, I ventured gingerly round Bala Lake, a distance of about 11 miles, during which the little car ran well given that it had just had new pistons and rings, and sounded a lot more contented. There is some tappet noise still, as I tend to prefer tappers looser rather than tight but the annoying small end noise has gone.I have to go to Wrexham tomorrow and I now feel confident enough to use the Seven for this trip and put a few more gentle miles on.
I have also paid especial attention to the sealing of the block to crankcase joint, and so far there is no sign of any leakage. Fingers crossed that it remains so!
.jpg   gangmower.jpg (Size: 135.42 KB / Downloads: 295)
Easy bicycle transport today.
.jpeg   C77ADCB2-EE02-43AA-842E-B39955F9E4B4.jpeg (Size: 156.74 KB / Downloads: 255)
