Drop arm ball removal
I solved this drag link problem by buying one of Tony Betts' new ones.
I then modified it by silver soldering a 3/8 disc onto the end cap and tapping it to make it adjustable (as per previous posts).  This has also meant that fitting doesn't require a sash cramp and it's now adjustable.
The improved drag link has however shown up that the steering box needs attention, so that's now on the bench.
Does lapping the steering gears in-situ really make that much improvement?
Charles
"Lapping gears"?   Yes, I believe it does.   But is is a long process.
I spent a day on my spare box - probably 3 or four hours' worth of lapping if you added it up, which got it into a usable state.
I reckon another hour or two would make it from "usable" to "good".
But it restores a box for which spares are not available.
I have not had much success with the turning of the gear through 120 degrees, I suppose the worm is always worn anyway.
If you do take the gear off to turn it, do not, whatever you do, hit the threaded end to try and knock it through the gear.
Hitting it will mushroom it, and fixing that is a pain.   And, having wrecked it, the gear is still fixed tightly on the shaft.
I made a puller from 1/4" bar, which eventually did the job.   But had to grind the gears in, after all.
Many thanks to everybody for their helpful suggestions.
John
Charles lapping the gears does make a difference. What you are trying to achieve by lapping is to adjust the central portion to take out the play then wear down the section at the end of each lock that is less worn (because of less use on full lock) so that it’s full travel is all warn the same and there is less or no play anywhere along its length.
John Mason.
Some consider very little or no backlash undesirable in which case lapping may not be worth the effort. The box on my car has done about 130,000 miles and with the gear turned but no lapping lost motion is about 1/4 inch.
A possible problem with lapping, if done in one position as soon as the mesh is altered a tiny degree rides on the unlapped. With car cwp the lapping machines oscillate the gears around a base postion slightly.
valve grinding paste is not very aggressive and breaks down. Carborundum powder needs very careful clean up and must not get into bushes.
As it happened, the draglink endcap came off without the need for compression as there was zero spring pressure on the cups.
Once straightened, I might follow Charles' example with the adjustable endcaps. I'm reluctant to get any of my sash cramps greasy.
Thanks again
John
(05-08-2020, 09:07 AM)John Mims Wrote: As it happened, the draglink endcap came off without the need for compression as there was zero spring pressure on the cups.
Thanks again
John
Goodness - how dirty is your steering gear ?
Thanks again
John
I don't like any oil or grease on my sash cramps because it always ends up on your work
It is wise man who keeps woodworking and metalworking tools separate.
Hi All
Wood and metal hmmmm.
I have separate sheds (of course I’m not showing off ?).
Although cross contamination is frequent. I’ve currently given up on trying to use my wood lathe with an 8”  swing to lightly skim brake drums. My metal lathe (substantially socially distant) has a meagre 3” even in the gap!
PS I have some sash cramps but like Charles invested in Tony’s Drag link ends modified with adjuster AND grease nipple!
