24-07-2020, 07:08 PM
Does anyone know of another A7 firing order other than 1.3.4.2. and if so, why?
1,3,4,2.
24-07-2020, 08:06 PM
I know very little about firing orders other than 1-3-4-2 seems to have been the most common among British manufacturers. I think I am right that the firing order of a side-valve Riley 11/40 tourer of 1927 which I owned a few years ago was (from memory)
2-4-1-3, and I believe that for the ubiquitous and very successful Riley 9 was 1-2-4-3. There will be others far better informed than me... Presumably though it was all at the behest of the engine designer, I can't see that any one would have been smoother than another, at least not in a 'four'.
24-07-2020, 08:10 PM
3 4 2 1 / 4 2 1 3 / 2 1 3 4 , or make a cam with the order changed around , same result ??
<p><br></p>
24-07-2020, 08:34 PM
1930s Standards (as made in Coventry) labelled the rearmost cylinder as no 1
24-07-2020, 08:55 PM
1243 used by Ford.
24-07-2020, 11:52 PM
Anticlockwise versus clockwise distributor rotation ?
25-07-2020, 07:58 AM
But 1342 and 1243 are the same engine when you number from the front or from the back.
25-07-2020, 08:55 AM
Indeed, Riley 9 is 1,2,4,3... Which I have to remember when I have my head under a different bonnet...
25-07-2020, 09:14 AM
(This post was last modified: 25-07-2020, 09:20 AM by Colin Morgan.)
Presumably there are only these two options - 1,3,4,2 and 1,2,4,3 with our shape of crankshaft? (As the next one that fires has to be 180 degrees out from the last.)
25-07-2020, 09:23 AM
True Renaud. Fire outward or inward whichever direction you number the cyls. Are you in lockdown perchance?
Whatever happened to the traditional questions like Why doesnt my dynamo charge? I dunno what the factors are. With separate manifold runs to each cyl as moderns the mixture distribution should not be affected. |
