this carb although similar to the 26 va is quite different . Can anybody identify the vehicle that it was intended for
Car type: 1934 Austin 7 AVH Van (in bits & incomplete!), 1936 Morris 8 Series I Tourer
There aren't any 26 VEHO in my Zenith Lists, though there are a number of 26 VEHG. Are you sure that's an O and not a G ?. Looks as if it may have been a conversion outfit for substituting a Zenith carb in place of a car manufacturers standard fitment be it Solex, SU etc. For example Zenith could supply a pair of 26 VEHG (48) B for the 1932 / 34 MG Magna or a single 26 VEHG (48) B for the 1931 / 34 Morris Minor.
Good afternoon. I have always believed that the 26 VEHG was the first sidedraft carb fitted to A7's after the zinc updraft.
It is a good example of how manufacturing developed over a period of time consisting of 3 sophisticated castings before the simpler 26VA was introduced. The spindle is also longer than the 26VA.
Stuart
Hi Stuart,
Yes it may well be a G. This would make sense as it came off of a 1931 car.
Thanks chaps. It’s knackered anyway , has large cracks in it.
My 1933 RP (made in september) is fitted with a 26VEHG carb.
When I had an October 1932 RN which had basically the same mechanics as the RP it was fitted with a 26VEHG, and strangely it seemed to be quicker and more economical than RPs with the 26VA.
Car type:
is it exactly the same choke size and jetting?
07-07-2020, 09:04 PM
(This post was last modified: 07-07-2020, 09:05 PM by Bob Culver.)
From memory it is same or similar as the Ten which has a larger renovable venturi whch could/should give more oomph (although i found an SU to be superior).
08-07-2020, 01:35 PM
My 1934 light 12/4 has a 26VEHG Zenith, and I suspect had it from new. The car has had few owners and is unrestored.
