02-07-2020, 11:20 AM
(This post was last modified: 02-07-2020, 11:20 AM by Ruairidh Dunford.)
You have mixture of at least two types there Jon.
Once you post the dog type we can advise on what the best way forward will be.
Also photograph the starting handles you have access to.
02-07-2020, 05:21 PM
(This post was last modified: 02-07-2020, 05:23 PM by AustinWood.)
Is your bush for 7/8" shaft? The thread looks a bit coarse to me but difficult to tell from a picture.
At one time John Barlow listed the starting handle bush. I think he still does as '29 type brass nut'.
The tolerances on the assembly are quite tight. The peg in the shaft has to rest on the ledge on the nosecone to hold the shaft horizontal and at the same time the collar on the shaft has to reach the bush to make it oil tight. The nut on my car is not screwed fully home and held with Loctite. This is to ensure the peg engages properly.
Personally - I would change the starter dog for the later claw type (primarily because they work and are very easy to obtain), this will work with starting handle shaft you have. Then find the corresponding nose cone and a suitable starting handle (you were going to post a photo of what you currently have - if you do this we can tell you which shaft it is for).
Car type:
The other photos are in post 10. I only have the 264 nosecone with the (possibly separate) bush, and don't have a handle yet. So if anything, it seems that the shaft is the odd one out?
I personally would still do as I suggest above.
Car type:
ok! thankyou R.
Jim - yes the bush was 0.9 inch so near enough 7/8". It seems to have a brass inner lining in a steel thread outer so perhaps its something which has been gnadgered around with, for a retapped nosecone in some other time.
I have obtained a small quantity of NOS early type starter dogs if anyone is struggling to find one.
The original bush is brass.
The early, 7/8", handles are few and far between. As Ruairidh says it might be easiest to find the later nosecone. The later starter dog should be no problem and the spring is readily available.
I'm not sure about the length of the later nosecone. To get the handle in the correct position it needs to be the same length as the early one + the thickness of the nut.
An additional benefit is the later dog works better than the early one. It the faces are worn it tends to get thrown out of mesh as you try to crank. I've just refaced mine.
