Clutch
Thanks Steve for the offer of angled screwdriver but have made a little gadget out of a piece of metal bar which when clamped to the chassis holds the shaft in place, don't know if it needs to be moved about as yet will try it out and get back to you Thanks Mike
Hi all, have managed to adjust the clutch, there certainly is not much movement cannot really tell much difference at the pedal end. Thanks for all the valued help from everyone. Cheers Mike.
