16-06-2020, 04:23 PM
Reg Number - Not Austin seven
16-06-2020, 04:30 PM
I can't help with the registration number, the vehicle is an E83W Fordson van, which was produced from 1938 to some time in the late 1950s.
16-06-2020, 05:35 PM
Unfortunately it's a very low-resolution photo. I doubt that anyone could make anything much of that. Where IS Shurlock Row?
16-06-2020, 06:08 PM
16-06-2020, 07:20 PM
(This post was last modified: 16-06-2020, 07:46 PM by Tony Griffiths.)
It appears - even if the original photograph is available - that the image will be too poor to read the number plate. If the original is available, look at it through a powerful magnifying glass; if a trace of the number can be seen, there is a slight hope that it might be recoverable.
(16-06-2020, 06:08 PM)Ian M Wrote:Bits are still the same...(16-06-2020, 05:35 PM)Martin Prior Wrote: Where IS Shurlock Row?
16-06-2020, 09:11 PM
looks like an E83W to me too. It's just about possible to make out the offset starting handle hole that these had.
