I need to make one so need the two key dimensions- overall length and the position of the engraving for "full". I can't find a sketch. I want to make an "improved" one that fits the hole slightly better!
Thanks
Charles
Full mark is 1 1/2”
Total length to underside of ball is 7”
I have one you can borrow to copy Charles...if you are around over the festive season
Don't worry John. I don't need an original to copy because I'm going to try and make it better than the original!
Btw I still have that head of yours - must pop over with it.
Charles
