19-05-2020, 09:05 PM
It would be interesting to know how the brakes balance, also with the brake pedal there where does the clutch pedal go Ruairidh?
Restoring a Top Hat
19-05-2020, 09:13 PM
Here Dave...
73EDC967-16D3-4A99-8C04-CF9E665DE356_1_105_c.jpeg (Size: 57.32 KB / Downloads: 533) The throttle linkage is an absolute hoot! Will try and find the picture.
19-05-2020, 09:30 PM
077CBD3E-5F5E-4F34-8F42-BD6BF437B290_1_105_c.jpeg (Size: 61.16 KB / Downloads: 522) D73A2DAF-B42D-4568-BA29-88D462E33097_1_105_c.jpeg (Size: 66.74 KB / Downloads: 522) DB2CC887-56A0-458F-8B65-BC7C57BDEE5B_1_105_c.jpeg (Size: 70.82 KB / Downloads: 522) 5CB19847-66C2-49BF-A8F8-7B6FA4B76B2D_1_105_c.jpeg (Size: 48.43 KB / Downloads: 522) 9D5DDD32-DA11-414B-A345-3ED76221FF6C_1_105_c.jpeg (Size: 73.84 KB / Downloads: 522)
20-05-2020, 09:20 AM
That tiny throttle linkage is hilarious!
20-05-2020, 11:36 PM
I thought the engine was mirror image ?
20-05-2020, 11:57 PM
21-05-2020, 01:23 AM
Thank you for this
26-05-2020, 07:15 PM
This weeks work
Or rather last week, I'm all behind! I was still stuck waiting for the engine bits to return so decided to have a go at the front inner wings. Didn't have a lot of time last week as I had to work 2 1/2 days but managed to sort them out. The offside wasn't too bad, some badly MIG'd over-patches had to be ground off and new metal let in properly. I don't usually bother to grind off the weld beads, they add character I feel! Nearside was in a poor state though, the panel had been repaired several times and was in a bad way. I had to chop off the last inch and let new metal in and then bend it in the right place. I think it's OK, we'll see when I start fitting the front wings...... Fortunately, the balancing shop is back in business and rang at the end of the week, so I went down and collected the crankshaft/flywheel/clutch/rods assembly on Friday (observing correct social distancing rules of course). This week is all about engine rebuilding, which I want finished by Sunday. I have a couple of weeks left but I'm then back to work full-time in June......
26-05-2020, 07:54 PM
Excellent
But work.... “Curse of the Austin Seven Classes”.... Cheers Howard Retired 17 years ago ?.
26-05-2020, 08:20 PM
As you say that is a hoot whilst the clutch pedal is interesting.
