HEAD STUD EXTRACTOR.
#21
(11-05-2020, 05:23 PM)Steve Jones Wrote:
(11-05-2020, 04:28 PM)Charles P Wrote:
(11-05-2020, 03:35 PM)Steve Jones Wrote: The set I've used for a long time is a Sealey AK724. Contains 1/4", 5/16", 3/8" and 7/16" extractors. Each also available individually. Coupled with heat at the base of the stud, pretty much works every time.
steve
Agreed.
I find that using oxy/acetylene and getting a lot of localised heat in quickly works much better than fanning it with a DIY butane torch.
c
Agree, oxy/acetylene rather than a butane torch. The block for my new Ulster engine had studs in a worse condition than those in the original posts and all came out without breakages, manifold studs as well. If you do break a stud, the drill guides as detailed in Woodrow work very well when used with the cylinder head. Simple to make if you have a lathe or know someone who does.
+1 on Oxy-Acetylene. Good and hot then a pair of Vise Grips, tighten slightly first then untighten a bit. Backwards and forwards until you can get near enough 1 complete turn. Then you have a fighting chance but they still will break.....
Lots of excellent advice above.
I've done my share of removing recalcitrant studs in various places, so my 20 cents worth:
1.Patience is a virtue, but accept that no matter how careful or adept you are there are some studs that will snap off just to spite you.
2. Use a decent stud extractor, I find the Sealey/Koken roller type is the best. The cam ones like the Sealey VS7232 will lead to disappointment. An oxy-acetylene kit for localised intense heat is a great help if you can access it.
3. Trying to go clockwise on the stud first to crack it loose is sound advice, as is backwards/forwards as it unscrews esp. back off if it starts to bind again.
4. Balance the force you are exerting on the extractor, I prefer to use a tee handle.
5. Use a quality penetrating fluid, most of us have our favourite. Even the old timers' trick of heating the stud then melting a candle against it where it threads into the block [allowing the melted wax to capillary into the thread] often works.
6. If you snap a stud, drill guides [even mild steel ones] are your friend.
7. If you have the kit and the nerve, sacrificing the stud by cutting it down to a stub and arc welding a clearance drilled nut on it [holding the nut down hard on the face of the block] allowing it to cool and then trying it with a spanner is worth a shot.
8. At all cost, avoid the temptation to use traditional ezy-outs on the remnants of badly seized studs, trust me it will end in tears [Image: blush.png] The only ones worth trying are the splined ones like your Sealey AK724, I have a set of SnapOn/Blue Point  spline type ones and even they have let me down once or twice...
Can often feel when going to break. Is it better to cut off tall so a drill guide sleeve can be made up and fitted over the stump?
Broken seized studs are a nightmare. Turn simple jobs into sagas.
I have a baby 6in Stilson wrench. Brilliant on recalcitrant studs. You can get right to the bottom of the stud, which I have found lessens the risk of breakage, and the wrench is small enough to get into most places.
This is exactly why I use a " Blue Point " as I mentioned previously. The jaws can reach the bottom of the stud but unlike a Stilson which is only holding the stud on two opposing faces, the three jaws are arranged in radial symmetry exactly as a drill chuck. Unlike a drill chuck which uses a key, the B.P. jaws are clamped by means of a spanner exerting immense force, so reducing twist and ultimate breakage of the stud.
Chris, I bought the Blue Point too following your earlier comments and now awaiting its arrival. Noted your valuable experience on this matter Mr. A.G.Wood especially patients
It helps if you are able to apply torque to the stud at the same time as striking it on the end. The shock helps to free it.
Hi, has no one used spark erosion it always works on a bare block. Used it many times myself,mainly on m/cycles & modern engines. Many general engineering shops do it. A good operator can also cut splines - internal or external to match an existing part. A few years ago I restored an old m/cycle, belt drive but the drive pulley from g/box was missing. Machined a pulley & a local gut spark eroded the splines to suit the output shaft.
Hi Jonblob, I aquired a block with a stud extractor broken off in it, had it spark eroded which was successful but cost £60. This would be a costly way if you had a number of studs to do.What do you normally pay?
I have a local guy, served his time building erosion machines. About £20 per stud. The splines cost about £40. Well worth it.
