01-05-2020, 01:57 PM
Hi
I am new to Austin 7s and this forum, looking for some guidance.
Finally stripped down the old engine (not run for at least 20 years) It was not seized and turned over relatively ok but a slight tight spot could be felt.
Does anybody have any ideas as to how the bores can have raise lumps in them? They are 0.060” oversized bores. The marks look like impact damage from outside the cylinder bore but you can't get to the areas where they are. Please see photos.
I have 3 noticeable raised areas, one in each bore in No. 1 3 & 4. They are about 1/4" in diameter. Could it be water / freeze damage before I acquired the car, they are all around 2.75 inches from the top of the block. The lower end of the water jacket is around 3" its the only thing I can think of.
I am not sure how thick the material is in this cylinder area and if these lumps could these be honed off as the rest of the bores look ok ? I guess they are only around a few thou raised.
No.4 piston has slight damage where the lump is but No.1 and No.3 do not.
Please see photos.
Any advice would be helpful and appreciated.
Thanks
Please see photos.
Thanks
