Has anyone with a vertical drive PA speedometer modified it from a 0-60mph to a 0-100mph?
Any information how to carry out this modification would be very much appreciated.
19-04-2020, 08:18 AM
(This post was last modified: 19-04-2020, 08:19 AM by "Slack Alice" Simon.)
I changed the spring in my PA, Robert.
When I first had the car, it only read about half speed - perhaps it was a Nippy's?
My spring was home made and so the needle wobbles about a bit.
But if I can do you, you will certainly be able to.
Simon
"Nippy's" ??? probably not. But - whatever.
The other alternative would be to fit a corrector gearbox from Speedograph. The mileometer isn’t gong to be correct but you should be able to work out the gearing needed to put the needle in the right place.
Thanks for the answers gentlemen.
Bob, how do you remove the bob weights to lighten them or change the spring?
The reason I ask is that the pivots are crimped so they can't be easily/safety removed.
Never had to remove the pins but it looks like the the 2 pins above the weights would tap out IF you gently ground the tails of the pins down a bit with a Dremel type grinder. Don't remove too much as you will need to peen them over once you have replaced the spring.
20-04-2020, 02:38 PM
(This post was last modified: 20-04-2020, 02:39 PM by Austin in the Shed.
Edit Reason: add content
I have asked several instrument people,including Steve H and non could accurately recalibrate a 60 to 100 mph.100 mph PA's are like finding rocking horse droppings as they were fitted to few vehicles.
