17-04-2020, 11:19 AM
(This post was last modified: 17-04-2020, 11:20 AM by Steve kay.)
You're quite right, on this machine the detail work makes it wholly forgivable. Was this snapped in the paddock at a speed event and did it go as quickly as appearances suggest?
(This reply was meant to be attached to the Buick post, but the mighty power has caused it to rush off on its own.)
Bella, I believe this car was built using fibreglass body sections for example the tail and scuttle at least, these are I believe copies from an Australian Meteor body that I am informed are are still available through the club there. The doors are I believe something added at the builders whim and the wings may well be modified steel austin. I know you have said not, but I suggest you look at the car more closely and this information may help your cause, you could conceivably argue that this is a Meteor replica, certainly that argument has more credibility than it being a Speedy replica. It may even be the case that the car was constructed in Australia before being imported to NZ, sadly form the moment the car appeared for sale here there have been attempts to deceive potential purchasers.
The dynamo is a 4 pole early 30s prior the 35A, but quite satisfactory.
18-04-2020, 09:02 AM
(This post was last modified: 18-04-2020, 09:03 AM by Reckless Rat.)
The scuttle is that part of the bodywork between the engine compartment and the passenger compartment, ie rearwards of the bonnet - the bit where the dashboard and windcreen is.
Car type: Austin 7 special 1934
18-04-2020, 09:30 AM
(This post was last modified: 18-04-2020, 09:42 AM by Bela.)
@Bob Culver
Thank you for identifying the dynamo. The dynamo field has no connection to an ignition switch. Therefore the field has no regulation by resistors. There is only a connection between the two connectors of the dynamo. I guess that is the reason for burned bulbs. Because German rules require additional equipment and the lights are a safety factor I will go for 12V with a dynamator.
@Reckless Rat
@ Ian Williams
I'm not really sure but the scuttle shows a little effect of magnetism. At this point it needs some more investigation.
Apparently many find LED lighting less expensive. If you are going to get involved in the electrics, and because it has a less common dynamo, the Cornwall site article A Charging Refresher will likely prove helpful.
Many run their cars with the dyn and Field directly connected so permanent full output. must not be run without connection to system and battery. With ignition only load, should not charge much above 8 amps. Should not damage bulbs, but all systems will if poor battery connection.
LED is a no-go for historical cars in D.
