06-04-2020, 01:58 PM
Hi Everyone,
I'm looking at restoring the dash panel and gauges for my 1936 Nippy. I'm fairly confident that I have the correct ignition switch and Speedometer, but I'm not so sure about the fuel, ammeter and oil pressure gauges. I was always under the impression that the fuel gauge and ammeter were fairly standard across the range but when I have checked the special parts list (1406NS) they are listed so would I be correct in assuming they aren't the standard's versions?
With regards the oil pressure gauge, I know that they were different (up to 60psi David Harcourt) based on whether or not the engine was force lubricated (which I believe was used from engine no: 241541), although my engine is 240XXX so in this case what version of the gauge do I need to use?
I've (hopefully
) attached some pictures of the gauges that came with my car but they were loose and I think they came from other projects.
Sorry to bombard you all with questions, I just want to try and expand my knowledge and prioritise restoring the gauges that would be correct for my car instead the 'incorrect' versions.
Thanks in advance
Matthew
I've (hopefully
Thanks in advance
Matthew
