06-04-2020, 04:41 PM
(This post was last modified: 06-04-2020, 04:47 PM by Steve Jones.)
Brake pedal again !
06-04-2020, 05:23 PM
06-04-2020, 06:02 PM
If it was mine - because I would want to use it first and do it properly later - I would mock up a "pedal box" to see what a solution would look like.
You have a cross section drawing, which you can relate to the cross member for position fore and aft. You know where you want your seat to be, and how high it is. You need to know how high the top of your pedal box is above floor level to give you comfortable movement of feet on pedals. You can work this out using carboard, sticky tape, and the living room floor. That will show you how much/little of the bulkhead/floor you can get away with removing to substitute with your box, which will put the pedals back where they belong. Or not, if it looks like too much mucking about with that bit of the car.
07-04-2020, 12:15 AM
It may have nothing to do with the problem but isn't the Ruby pedal and shaft 'upside down' in the arm in the first picture ?
08-04-2020, 09:22 AM
Determined to find a fix without dismantling the car to far decided to try the Ruby pedal again.
Now fitted giving a much improved operation , problem now being when simulating hard braking the pedal lever is very close to the throttle control shaft (see photo). Solving one problem has lead to another and I can't see how to solve it. Just wondering if anyone out there has a solution? Many thanks Paul
08-04-2020, 10:25 AM
Hi Paul
I think the accelerator linkage is too low. On my RK and on my special it is mounted on the bulkhead about 3” higher than yours. The accelerator lever is mainly on the engine side of the bulkhead and only the pedal comes through into the cockpit. From your photos you seem to have lots of room to site the linkage higher up on new brackets. Fabricate a new accelerator lever attached directly to the end of the linkage. It will mean that the accelerator pedal can be sited well below the brake pedal. Cheers Howard
08-04-2020, 12:02 PM
Thanks Howard that's very helpful, would you have any photos available of your fixing position?
Many thanks Paul
08-04-2020, 01:00 PM
Wear trainers
08-04-2020, 02:13 PM
Hi Paul
As it happens I have the gearbox out to replace the clutch levers (see thread on 4 speed release bearing). These show the position of the linkage and the juxtaposition of the Chummy brake and accelerator lever. Note I’ve “straightened” the brake pedal slightly but using a Ruby pedal should give quite a lot of adjustment to position and length. Cheers Howard
08-04-2020, 02:19 PM
Thanks Howard that's great.
I imagine with this forced shutdown a lot of tinkering going on at present. The Joy's of Seven ownership. |
