References to speedboat carbs got me thinking about carbs on Meadows engines. In car use almost always SUs, but I cannot recall whether or not the Meadows in double diagonal speed and RAF boats had SUs or another make. There used to be a couple of such on Loch Lomond and the Scottish Maritime Museum certainly had at least one ex-boat Meadows in the stores, maybe one of our distinguished Scottish members might investigate. There are certainly none on the Mon & Brec, otherwise I'd go out into the rain and peer into the engine bay.
What a wonderful batch of diverse replies!
The test in question was going uphill, so under max load.
5.67 axle ratio, so not doing 68 mph in second on a 3 speed box!
Float chamber is vertical.
Blue spring fitted.
Damper oil is 3 in 1, so pretty thin, but thicker oils always seem to give so much resistance in winter temperatures - any thoughts on this being contributory?
Being pragmatic about this - is there any other symptom apart from a momentary drop in AFR?
No other symptom - just curious to find out what's going on!
I knew one of the more experience chaps would have some answers........
Hi Bob, if when cornering it throws the piston upwards I think it would momentary weaken the mixture which is even more odd!
Dave
I'm not sure you are right there Dave - if the piston goes up, it takes the needle up which increases the gap around it and the jet, hence letting more fuel through.
I am using a no. 6 needle which I have modded a little in search of perfection - which of course I never find!
Yes Bob, it seems daft but as the venturi opens less suction hence less fuel even though the needle should allow more fuel (at a given RPM & butterfly opening).
Dave
