You don't have to, Chris, you remove the top hat section from the bottom bush to create the space. I've looked at these for the Ulster but I worry about needle rollers exposed to the elements. However, isn't this a source of hard washers for a big 7 axle?
I guess with many newcomers now with little acquaintance with traditional old cars and machinery a lot of reinventing is inevitable.
On other cars unsupported floating cylindrical oilite bushes are prone to break up.
Much can be done with blue and careful work with a very fine file. A new top hat bush slid over a kingpin could be used to apply blue (or equiv) to the axle face to test if this square.
I suppose it is desirable to reduce vertical float to keep dirt out and to reduce hydraulic hammering of the kingpin, end plugs etc; otherwise of little consequence, although wof inspectors do not like.
It is hardly a crime to pack the non thrust face with a soft washer filed to suit, or cut shim.
With the very low weight on front axle, the availability of moly grease, the small Seven is a lesser candidate for further friction reduction.
For some, Sevens are primarily the base for precision hobby. This is fine but the associated fancy standards if touted as the norm can deter those who just want a reliable car functional as original .
When I said I wouldn't I was warning against the notion that it could be a good idea, rather than suggesting it was necessary! Points taken.
I'm with Alan & Bob on sintered materials - not knocking Oilite but these materials are inherently brittle. That's fine in an installation which is designed with such characteristics in mind. Come to that, needle rollers don't tend to fare too well in applications where they are static and subject to vibration. That's my two penn'orth...
Fitting needle roller thrusts were covered in an old post.
Refacing the axle eyes and inside the top of the stubs can be necessary when the king pins have worn loose.
Needle roller thrusts lighten up the slow speed steering a lot and they need shielding too.
If the castor is out the car wanders very freely!
Car type: 1929 AD Tourer, 1930 Rosengart LR2, Rosengart LR4 Van 1938 APE Tourer (Opal)
This is the first time that I have read this thread, somebody mention reinventing the wheel. I had the same problem with my Rosengart LR4 with knackered eye surfaces and came up with the same idea to use a tap reseating tool on an old king pin. The more difficult thing for me was that the LR4 has larger kingpins and bushes than the Austin seven, these had to be made in house.
TAP SEAT CUTTER
I have found only one in a builders suppliers so far and that had 1/4 inch and 3/4 inch cutters......no good for big 7 1 1\16 inch required.........nor for A7 15/16 inch thrust faces (a7c told me the thrust size)
Hello Chaps
For what it's worth my racing bicycle headsets are tapered needle roller bearings, I've been using waterproof wheel bearing grease for many years and yes they do require periodic cleaning and re-greasing but the waterproof wheel bearing grease has kept them alive and rolling for good periods between rebuilding even with the odd very wet racing event, so If anyone is considering using those needle roller thrust bearings for anything like a TA/TB/TC or even a modified A7 application, I'd advise not using your regular garage grease in there...
As an aside I switched all our classics over to waterproof wheel bearing grease in the suspension points years ago & have had no issues at all.
My 0.02p's worth anyway...
Greig
Sunny South Africa
Several 7's
Triumph Super 7
MG TC
Others
Is no one capable of using a file anymore?
