18-01-2020, 09:53 AM
Fuel tank slosh sealant
18-01-2020, 10:27 AM
What type/make of sealant had you used please Henry?
18-01-2020, 12:38 PM
And how long ago......
18-01-2020, 03:57 PM
Just don’t tell me it’s Sureseal Products as five years in I am very happy
18-01-2020, 04:03 PM
That silver stuff looks like the same stuff slowly bubbling up in my box saloon tank.
18-01-2020, 05:00 PM
When I did my tank I chose 'TAPOX' sealant. There are some "ethanol resistant" products about but few that claim to be "ethanol proof". The recommended rust converter is 'FERNEX' and the two things come as a kit. I spent hours on the preparation and only when I was certain that there were no more rusty bits did I apply the sealant.
I got into trouble because I left the tank in the airing cupboard to fully cure. It smelt a bit!!!
18-01-2020, 05:17 PM
It’s a mild steel tank from a recently concocted Model T racer imported from New Zealand.
The body parts, including the tank are less than 10 years old and are commercially produced and available online from Model T spares suppliers. The sealant was not administered in this country so my guess is 5+ years. Ethanol laced fuel and mild steel are poor partners. Nothing that I know of will adhere to rust. The long term solution, apart from using ethanol free petrol, is probably a brass, stainless steel or plastic fuel tank.
18-01-2020, 05:40 PM
having been plagued by rust in the tank of my Seven, I had my tank professionally cleaned and then sealed it with an ethanol proof sealant from Rustbusters. That was almost exactly 12 months and 5k miles ago. Had no problems since.
18-01-2020, 05:56 PM
I have used this on about a dozen tanks Henry: https://www.frost.co.uk/por15-motorcycle...gLlX_D_BwE
Prep. and full process is time consuming but essential - the first tank I did was on my Pearl about 8 years ago and it is still giving service without issue.
18-01-2020, 06:10 PM
The Austin tanks I have dealt with have been tin/lead coated steel, ‘Terne plate’ or something similar with soldered joins and unions and they seem to survive ethanol as long as the coating is not damaged.
