Car type: Ashley 750 Special
I’m working with a 22fz updraft with little success.
I read the SU side draft is the better performing but is there a preferred SU ? Can I put on an HS4 or any carb and needle or according?
Any thoughts appreciated.
The SU OM card fits on a ruby manifold they are used on Morris minors and MGs
I use a one inch side-draught pre-war SU bolted, with thin adapter, onto a ruby manifold with the restricting venturi orifice ground out.
This is on my RF saloon in place of the updraught Zenith. All-round improvement; simplicity, adjustability, starting and performance.
My theory is that Sir Herbert would have used S.U.s if they had not been owned by his arch rival.
I think you would be looking for an 1" / 1 1/8" SU carb. You would need the Ruby style manifold and you will need a block to change the mounting holes from vertical to horizontal. If you have the pre Ruby (Alloy up draught ) manifold, then you will need something a bit special making in the way of inlet manifold.
Also if you have a front tank, you will need a fuel pump or ensure the carb bowl is low enough for fuel to flow from tank to bowl.
See SU on this forum.
16-01-2020, 02:17 PM
(This post was last modified: 16-01-2020, 02:18 PM by Alan.)
I use that set up on my Chummy, too. Only downside is as far as VSCC are concerned you are no longer “standard”. It works ok without a fuel pump as well.
Later 1 1/4" SU's also work fine and are easily picked up at jumbles.
Later 1-1/4" SU with blue spring and no.6 needle works well
If using an early block remove the nice knurled nuts and replace with standard nuts before fitting the 'Ruby' manifold.
