10-01-2020, 02:41 AM
(This post was last modified: 10-01-2020, 05:43 AM by Tony Press.)
Just checked the two original Car Number plates with a new bright torch - and the letters/numbers do look etched - never checked that closely before ! Very steady hand to get them in such a nice line.
I am curious as to why the Car Numbers were etched in Australia on build- when I checked the surviving 1930 Longbridge ledgers, I was advised the build date and the Car Number for each car.
The early Holden bodies ofen carried the ID plate-
1928 Holden badge.jpg (Size: 86.6 KB / Downloads: 357)
sometimes mounted on the door pillar.
Later-
1929 Holden Badge.jpg (Size: 19.45 KB / Downloads: 355)
sometimes mounted under the passenger's door on Fabric Saloons.
Under the back seat in my Fabric Saloon there is an aluminium Holden Job Number plate-
I have a picture of a similar plate from another car.
Tony.
Car type: '27 Chummy, '34 Special, '50 Traction Avant
11-01-2020, 02:23 AM
(This post was last modified: 11-01-2020, 02:24 AM by Mark McKibbin.)
Tony, it looks like they got the "N" around the wrong way...definitely need an Up on the N stamp!
Another oddity with my car is a steel skuttle, I am assuming someone has made a replacement and it was a raffle prize 25-30 years ago.
Mark
Strangely it seems to be back to front (and not a Z as I first thought) !
From memory Bill has noted some Australian bodies had a locally made steel scuttle.
This was the body builders plate I found on my car
BODY PLATE FOUND WITH MY A7.jpg (Size: 47.06 KB / Downloads: 266)
From what I understand Properts made bodies based on Holden steel pressings for the chummy.
Stephen
11-01-2020, 10:21 PM
(This post was last modified: 11-01-2020, 10:37 PM by Tony Press.)
An interesting company- Propert from Sydney NSW originally made kitchen utensils - scales, whisks, beaters etcetera and after a brief foray into car bodies (from pictures we were given the whole range of Austin 7 bodies) went on to make caravans in the 30's.
The name still exists selling scales but now they are made in China.
(11-01-2020, 03:19 AM)Tony Press Wrote: Strangely it seems to be back to front (and not a Z as I first thought) !
From memory Bill has noted some Australian bodies had a locally made steel scuttle. Yes I was not thinking, an N should be right either way, so a faulty stamp? I wonder how many cars got that one? I will ask Bill about the steel scuttle maybe it's not a Holden after all.
Mark
13-01-2020, 10:31 PM
(This post was last modified: 13-01-2020, 10:33 PM by David Cochrane.)
I made a list of all the CHA1 numbers that I could find in the Chassis Register together with their Chassis numbers:
15013 CHA1-847
19834 CHA1-830
27751 CHA1-1758
29386 CHA1-2491
34326 CHA1-2970
44403 CHA1-4189
51146 CHA1-4729
45568 CHA1-4832
48088 CHA1-5936
49918 CHA1-6664
CHA1-6692
CHA1-8191
53723 CHA1-8531
55342 CHA1-9273
Mark, it seems odd that your car doesn't seem to fit into this list in the 'right' place. Chassis no.48088 is also an Australian Chummy.
David
Car type:
(10-01-2020, 01:55 AM)Steve Bryant Wrote: My car was an Australian car and the car number also appears to be engraved not stamped.
As far as i know the plates are original.
Stephen Steve - is 1624, presumably the body number, stamped on your transmission tunnel and possibly hinges?
(10-01-2020, 12:30 AM)Ian Williams Wrote: One of the things which seem to confuse many, particularly newer owners, is that a car number and a chassis number are not the same thing. For example Chummy car number; AD 4*** will not be chassis number 4***, the exception being mid to late 30's cars when Longbridge changed the numbering system bringing the two line. It stands to reason that the works would enter a number into the ledger for a chassis supplied bare with the prefix CHAI, if so then Mark may have the 4,729th bare chassis supplied, I wonder how many chassis had been exported by 1927?
Ian, re the AD 4xxx number. Surely that's the body number ? The car number would be Anumber-more numbers.
