Can anyone advise of a supplier of the pressed steel, lower, inner supports for the Nippy/Speedy/Chummy rad shells? Also the correct description would be good! Mine got attacked badly by salt on my way back from Curborough in 2018.
Car type: Austin 7 RN 1931
I’ve seen various new chassis and body parts advertised on ebay, a long search through the bits and pieces on offer might yield results
Do you mean the corner reinforcement or the radiator support brackets. ?
Either way it is going to be a bit of metal bending /fabrication.
Ruairidh, you're spot on. It's the two strengthening channel sections that follow the curve of the lower radiator cowl that I'm after. Any ideas?
I have some new ones that I think were provided by Keith Marriner a long time ago.
I could ask a friend, who is doing fabrication work for me next week, if they could be copied for you?
I would like as pair as well please.
I will ask him for you Gene.
Gene, my friend is asking if you trade under “tryingtoclear” on eBay please?
