Car type: '34 RP ,'30 RF
Hallo Eddie
If in "the North" look up 'The Ulster Pre-war Austin Club' if RoI talk to me at 'Cairde an Seacht bhig' - might be able to help
Ian Clayton, Bantry, Co Cork 027 52759
Bravo, another hidden gem heading back to the road.
Andy B
Nice little project. From stradbally?
Car type: Austin 7 Ruby 1935 CYA 695 very poor condition
I started work on one of the two stripped engines that came with the car. Both very badly corroded, one seized on both the crank and piston seized in block with bent con rod. the other engine looks salvageable. tried the rings in the bores and have 0.050 ring gap, a little too much i feel. Does anyone know if i can get +0.040 rings to suit Specialloid pistons and where would i get them if possible?. These rings look thicker than the other piston rings on the other engine.
There are many good suppliers. I have only dealt with tony betts alot. Reasonable on postage to Ireland.
Was this ruby outside stradbally?
John
Thanks John. I have just looked at his webpage. He does not say if he has oversize or different make, so i will send him a mail. Thanks for the reply. In relation to where this car was, I purchased it from a guy just outside Ballylinan in Athy. Thanks again.
That's the one! Congrats! Great project.
Tony Betts replied that he does not stock these rings.
Car type: 1937 Nippy
Hi, Many years ago when I was selling copiers and fax machines I had a customer in Sheffield called "The Standard Piston Ring Company". I've just had a quick look and it appears they are still going (in Rotherham now).
Without looking too closely, their main web page talks about making rings between 11 mm and 17 metres so maybe they can help?
Best wishes in your search,
Nick
